GTX 980 Power Question
Go to solution Solved by Real_PhillBert,
my psu is a cx750m and it has 2x 6+2 pin connectors aswell as 4 x 6 pin sata/molex etc
Just use the 2x 6+2 connectors and leave the +2's unconnected.
My GTX 980 has two 6 pin connectors and  i am wondering if i can use a split 6pin or do i need two separate cables from my power supply
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/244151-gtx-980-power-question/
It's not recommended, but it's possible if you're a complete madman
But if you have a 980 and you need a splitter cable for your PSU, maybe just get a new PSU...
Specs: CPU: AMD FX 6300 Motherboard: Gigabyte 970A DS3P RAM: HyperX Fury 16GB 1866MHz GPU: MSI R9 270 OC edition Case: Sharkoon VS3-S SSD: Samsung 840 EVO 120GB HDD: 1TB Caviar Blue PSU: Corsair CX500W
*If I say something that seems offensive, please don't take it seriously, it was most likely meant as a joke/sarcastically*
https://linustechtips.com/topic/244151-gtx-980-power-question/#findComment-3348546
no i dont need one i have enough, its just one split cable looks better
1
https://linustechtips.com/topic/244151-gtx-980-power-question/#findComment-3348571
Wait, does your PCI cable from the PSU have two 6+2 connectors on one end? If so you can do that and you are perfectly safe.
If your PSU only has one 6 pin or 6+2 pin connector, you need a new psu.
https://linustechtips.com/topic/244151-gtx-980-power-question/#findComment-3348601
1
https://linustechtips.com/topic/244151-gtx-980-power-question/#findComment-3348684
https://linustechtips.com/topic/244151-gtx-980-power-question/#findComment-3348699
ok thanks
1
https://linustechtips.com/topic/244151-gtx-980-power-question/#findComment-3348740
