http://pcpartpicker.com/user/Revan117/saved/fwFCmG
http://pcpartpicker.com/user/Revan117/saved/fvtkcf
Which should I choose?
MSI Radeon R9 280 3GB TWIN FROZR   vs   EVGA GeForce GTX 760 2GB Superclocked ACX
Don't plan on overclocking. For casual gaming, and programming. Is this a good building, because I'm trying to stay under $1000.00 dollars.
https://linustechtips.com/topic/243771-need-help-with-my-first-build/
I would go with the 280 or 290 or even a GTX 970 if you can afford it
Yes Yes Legalize Gay Marriage sure, but have you ever considered Weaponizing Gay?
CPU: I5 4690 3.5ghz || MOBO: MSI B85-G43 Gaming Board || RAM: 8GB Corsair Vengance Pro - Red || GPU: Gainward GTX770 Phantom 4gb || PSU: EVGA SuperNova 750W Gold || Case: Thermaltake Urban T31 || SSD: Corsair Force 120GB || HDD: 1TB WD Black
http://pcpartpicker.com/user/mistersprinkles/saved/sHTFf7
Here's a build with an R9 290 for under $1000. Better SSD and better case than in the OP's original build.
Much better GPU too.
Intel Inside. Overweight guy in his 30's outside.
I'd suggest u to downgrade ur monitor and remove the SSD for now to afford 970 since its way better performance than r9 280& 760.
Here is my suggestion.
u can add SDD when u afford it.
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor  ($214.99 @ NCIX US)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($64.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($349.99 @ Amazon)
Case: Enermax ECA3253-BL ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($40.98 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($16.98 @ OutletPC)
Monitor: Acer H226HQLbid 60Hz 21.5" Monitor  ($119.99 @ Newegg)
Keyboard: Cobra Cobra II Wired Standard Keyboard  ($42.42 @ Amazon)
Total: $1023.30
Generated by PCPartPicker 2014-11-03 01:24 EST-0500
My rig:
CPU: Intel Core i7-4790K
Motherboard: ASUS MAXIMUS VII HERO
Graphics Card: Gigabyte GeForce GTX 980 4GB GDDR5
RAM: Corsair Dominator Platinum 16GB
SSD: Samsung SSD 840 EVO-Series 250GB
HDD: Seagate Barracuda HDD 1TB
Monitor: ASUS PG278Q ROG Swift 27-Inch Screen LED-Lit Monitor
Cooling: Corsair CPU Cooler H100i
Power Supply: Corsair Professional Series Platinum Power Supply AX860i
PC Case: Corsair Graphite Series White 760T
