RAM Speed
Go to solution Solved by harrynowl,
CPU-Z also says 800Mhz, just like Speccy.
Stupid task manager.
Ok, should be running at 1600mhz then :)
please mark the thread as solved if you're done here :)
Hi,
I have 8GB (2x 4GB) of ddr3 ram clocked at 1600Mhz (standard). I noticed windows doesnt recognize it's speed, and says it is 667Mhz.
Then i checked in speccy, and there it is the same. 667 Mhz.
Why is this?
Thanks in advance.
"I fart in your general direction" -The Frenchmen
https://linustechtips.com/topic/243478-ram-speed/
go into bios and turn on the xmp profile for 1600Mhz, the number it says on the package is what the manufacturer tested it for, before downclocking it(for mobo compatibility) if you want advertised ram speeds you actually have to overclock it... but wouldn't you hate it more if you put ram in your mobo and it fried or didn't work and you had to find a mobo it was compatible with and down clock it your self? Also you have 2 dimms so multiply the number by 2 you are currently at 1333Mhz...
5820k4Ghz/16GB(4x4)DDR4/MSI X99 SLI+/Corsair H105/R9 Fury X/Corsair RM1000i/128GB SM951/512GB 850Evo/1+2TB Seagate Barracudas
https://linustechtips.com/topic/243478-ram-speed/#findComment-3334374
That'd be DDR3-1333MHz.
Have you set XMP in your UEFI?
Nope, it was on auto.
So i changed it to XMP 1.3, and set the XMP 1.3 to 1600Mhz.
Now i checked in tastmanager and speccy, but nothing changed.
https://linustechtips.com/topic/243478-ram-speed/#findComment-3334448
Ok, reloaded to UEFI and changed the timings.
In the UEFI they appeared to run at 9-10-10-25. Out of the box, they should be 9-9-9-24.
So i set them manually to 9-9-9-24 and now speccy seems to appear the frequency as 800Mhz, but task manager still show 667Mhz.
Why? And why does the frequency change when i lower the latency?
https://linustechtips.com/topic/243478-ram-speed/#findComment-3334479
What does CPU-Z say?
And no.
https://linustechtips.com/topic/243478-ram-speed/#findComment-3334554
https://linustechtips.com/topic/243478-ram-speed/#findComment-3334918
