I don't know how or if this would work, but I was thinking about getting the corsair h55 with the kraken g10 while it's on sale today for my 290.  If I get a second 290 in the future, I won't be able to put a kraken g10 on it because there isn't enough space, and the g10 is too wide.  is it possible to use 1 or 2 normal gpu water blocks with an aio?  I think there's a swifttech aio that is expandable, but idk...
I don't really know what I'm asking
Okay.. Without doing a full custom loop(because they cost too much) would there be a way to water cool a second graphics card? or should I just get the h55 with the g10, and maybe add a normal air cooled card in the future?  I can't use two g10s because one of the cards can only be 2 slots wide.
XEON E3 1231v3 | GA-Z97MX GAMING 5 | XFX R9 290 | 16GB RAM | CRUCIAL MX100 256GB | WD BLUE 1TB | EVGA SUPERNOVA 850W | CORSAIR 350D
https://linustechtips.com/topic/243465-expandable-aio-for-gpus/
Chop up a g10 so it fits in 2 slots? Or just stick to air cooling, if it's only 1 gpu that outputs the heat into your case it should be fine...
Or go complete custom and ghetto-mount it? It has been done before a lot and if it's done properly, it works fine.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/243465-expandable-aio-for-gpus/#findComment-3334149
The H220, H320, H220-x can all be expanded and easily handle a graphics card maybe two added to the loop. I since you only have room for a maximum 280mm RAD I'd say the H220-x is your best bet.
Sky Pollution | i5 3570k @4.8Ghz | MSi z77a g45 | MSi GTX 770 Gaming 2gb | Samsung 840 Evo 250gb, Samsung OEM 500gb HDD | Corsair CX750m | Corsair 760t White Edition |
Corsair M95 | SuperLux 668b's | Logitech C615 | ViewSonic VX2250wm | Random OEM keyboard until I rage break it and grab another random OEM keyboard from my pile.
Build Log: http://linustechtips.com/main/topic/186413-sky-pollution-my-white-760t-build-rebuildupgrade/
https://linustechtips.com/topic/243465-expandable-aio-for-gpus/#findComment-3334214
the H220X allows you to add custom parts
okay, so if I got a h220x, I would need to get a water block like this?
http://www.frozencpu.com/products/24128/ex-blc-1716/EK_MSI_Gigabyte_Radeon_R9-290X_VGA_Liquid_Cooling_Block_Rev_20_-_Acetal_Nickel_EK-FC_R9-290X_-_AcetalNickel_Rev20.html?tl=c599s2078b133
that's already $270, what else would I need? like tubing, fittings, etc?
https://linustechtips.com/topic/243465-expandable-aio-for-gpus/#findComment-3334446
how would I go about chopping up the g10?
and what do you mean by "go complete custom and ghetto mount it"?
https://linustechtips.com/topic/243465-expandable-aio-for-gpus/#findComment-3334466
Well you're going to need a yard of tubing, I believe the mounts on the rad and cpu block are 3/8 ID but don't quote me on that. Then you're going to need your choice of fittings just for the intake and outflow of the block. I'd say compression fittings are your best bet but this is where my knowledge starts to fade and I'm not really comfortable on recommending brands or what to use.
https://linustechtips.com/topic/243465-expandable-aio-for-gpus/#findComment-3334515
get a G10 and cut off the part that's in the way. It will maybe won't look that clean, and maybe will make the part to mount a fan unusable. but if you can live with that go ahead.
And with ghetto mounting i mean something like they did on this forum: http://www.overclock.net/t/1047888/corsair-h50-h70-antec-kuhler-620-920-adaptor-for-gtx-480-570-580-interest
https://linustechtips.com/topic/243465-expandable-aio-for-gpus/#findComment-3334586
okay... I'm just not sure I want to spend that much, it's getting close to what a custom loop would be, and I can get a g10+h55 for only $65...and a new 290 is cheaper than the h220x and waterblock...
https://linustechtips.com/topic/243465-expandable-aio-for-gpus/#findComment-3334611
okay, I'll look into that
https://linustechtips.com/topic/243465-expandable-aio-for-gpus/#findComment-3334617
Yea at that point it is a custom loop, I mean you also chose like the most expensive gpu block you can get but either way custom loops aren't worth the performance gain in terms of price.
https://linustechtips.com/topic/243465-expandable-aio-for-gpus/#findComment-3334739
How cheap can I get a good gpu block then?  I don't really know what there is, I've only really heard of the EK ones
https://linustechtips.com/topic/243465-expandable-aio-for-gpus/#findComment-3334760
Like $90 for the alphacool nexxos one. Still not really worth it in terms of performance gains especially since you can't OC you're cpu.
https://linustechtips.com/topic/243465-expandable-aio-for-gpus/#findComment-3334819
yeas, if its a switech one and it fits the g10, and i dont think swiftech ones do fit the g10
Can the h220x be used with the kraken g10?If not, are there any aio's like the h220x that can be used with the g10? So I could use it with the g10 on one gpu and then use a normal gpu block on a second gpu?
https://linustechtips.com/topic/243465-expandable-aio-for-gpus/#findComment-3335500
the h220x is not on the support blocks for the g10
https://linustechtips.com/topic/243465-expandable-aio-for-gpus/#findComment-3335518
No it cannot, the H220-x uses a standalone cpu block that you would normally buy if you were doing a custom loop. Might want to check out if the normal H220 can though since it uses the old design.
Edit* scratch that, the h220 can't be used with the g10 either.
https://linustechtips.com/topic/243465-expandable-aio-for-gpus/#findComment-3335552
are there other aio's like the h220x that allow for more parts to be added to the loop?
https://linustechtips.com/topic/243465-expandable-aio-for-gpus/#findComment-3338197
Short answer: No
Long answer: possible but don't even waste your time.
https://linustechtips.com/topic/243465-expandable-aio-for-gpus/#findComment-3338752
