Triple display ultra widescreen possible?
Ok so I recently upgraded my pc:
i7 5820k
16GB DDR4 2133Mhz ram
970 GPU
And I am wanting to go triple display now I really like the ultra widescreen displays so was wondering would it be possible to go triple display gaming with 3 of those bad boys? with atleast 40-50FPS on say BF4? I already get around 150-160 FPS in bf4 on ultra 1080P when streaming.
https://linustechtips.com/topic/242863-triple-display-ultra-widescreen-possible/
970 is a little weak for 3x 1080p 21:9 monitors
it should manage 3 16:9 1080p displays though if you can sacrifice AA
If it's 12:9 then it's not 1080p is it? :P
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
1080 is the pixels on the height... is 21:9, the 9 are 1080 pixels, the 21 are 2520
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
we use K for horizontal pixels and p for vertical. so a 1080p monitor could also be called 2k
 1080p (HD) is a digital media standard for television, as is UHD ( marketed as 4K but one of many 4K's). They are all 16:9. The guys who define the standard come up with the name so it's easy for people to refer to the whole resolution without having to say it in full. When it's an uncommon resolution, or non standard, just saying the amount of pixels in height or width doesn't say much at all.
Regarding K for horizontal pixels, 2K is even less descriptive than 1080p since it's 1920px wide. (1.92K?) there is also another 4K (used in movies) that is 4096px wide, and UHD is 3840px wide but they both have the same height. True, specifying an aspect ratio does help, but why not just specify the other dimension instead?
1080p is 1920x1080, 1080p isn't 1x1080, 2x1080, 2560x1080 or 10000000x1080. If it was it would be pointless using it to describe a 2d resolution if only one of the dimentions is specified.
I usually hate on '1440p' since that isn't really a thing, but it is more suited to the moniker since it follows the same lines as the 16:9 digital media standard (and a multiple of HD) compared to what i'm on about above.
</rant>
Haha edit: i thought you said 21:9 rather than 16:9 but either way my point still stands.
</rant>
lol you should realise that official wording and the short hand people use are different, p for vertical res and k for horizontal (which we round)
I'm actually surprised no one has commented with "I run triple display ultra widescreen's" but from what I have been researching I "Should" be able to get around 30-40FPS on BF4 so thinking of upgrading to 970 SLI but I will be saving up 2 months to actually afford another card + 3 ultrawidescreen displays :)
I run triple 1080p monitors... ultra wides would be nuts!
I don't know of a single card that can even run my setup with 50+ FPS...
I currently have 2 7970s and usually sit 45+ in most games.
I know, i know, but still ... you can't describe 2 dimentions by just saying one of them. Even less so when you aren't even specific about one of them and round it.
1k. What's that? 1440x900? 1280x1024? It's not much effort to go to so that someone knows exactly what you're saying.
In your case, when you said 1080p sure, you mean 1920x1080 which is what 1080p is. But by saying 1080p 16:9 you're either overly specific or you mean that there are a variety of 1080p's which there aren't.
21:9 1080p
21:9 1440p
16:9 1080p
16:9 1440p
16:9 2160p
much easier then using any of the Ultrahd or ultrawideHD.
21:9 1080p
21:9 1440p
16:9 1080p
16:9 1440p
16:9 2160p
