I recently built an amd budget machine how did i do for the 1100 dollar price tag?
Phanteks pro full tower
Corsair ax760i
Sabertooth 990fx
Fx 6300 oc'd to 4.7
Ex240 XSPC custom loop liquid cooler kit
8gb gskill sniper 1866
Samsung pro ssd 128gbx2
Evga geforce 760 oc'd to 1150
7 pwm phanteks fans 140mm and 1 200mm
Running my games at max all of em some latest gen to things like wow. I think i did well aside from lighting in my case its a solid build i think any thoughts opinions or suggestions please
https://linustechtips.com/topic/242771-diy-project/
It's a decent machine. You're not going to set any world records with it, but it's decent.
If it's exclusively a gaming rig, it would have been possible to garner better performance with Intel, and a 970.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/242771-diy-project/#findComment-3326334
I'm sorry, but I just have to point this out - why is this topic in New Builds and Planning? Shouldn't it be under Build Logs?
I actually couldn't underclock my 5 year old GPU to make it as slow as a next-gen console.
#pcmasterraceproblems
~Slick
https://linustechtips.com/topic/242771-diy-project/#findComment-3326413
Gpu was a concern it started with 2 low end raedon cards i got used the 760 was really pressing the budget the fans were bought initially for the rad but wouldnt fit so i dont use the pwr supply mask that came with the case and have one on the hdd cage and one as a bottom intake - tempted to break out the dremel on it and cut a few air ports or even a cut out for a fan to mount onto it - thoughts?
https://linustechtips.com/topic/242771-diy-project/#findComment-3326460
