Yes. Using PrecisionX or Afterburner, there should be reset buttons(at least on Afterburner. I don't use PrecisionX).
https://linustechtips.com/topic/242667-overclock-help-needed/#findComment-3325224
yes mate you can most oc software will allow you to reset and to save your perset
I5 3570K@ 4.4 - GIGABYTE Z77- Kingston 8G 2400 RAM - MSI GTX980 - HAF-X - 27'' ROG SWIFT + 32'' LG IPS - OCZ 250G SSD + WD 4TB HDD - ASUS XONAR DX -Noctua NH-D14
https://linustechtips.com/topic/242667-overclock-help-needed/#findComment-3325225
I took a snapshot for you.
https://linustechtips.com/topic/242667-overclock-help-needed/#findComment-3325237
GT210 can not play that game at any clock speed. Sorry. I'd save time and just buy a better card. R7 250x is cheap and can play med 1080p no issues.
https://linustechtips.com/topic/242667-overclock-help-needed/#findComment-3325600
