Yes, but do it with PWM control rather than voltage control (unless you already have a DC fan hub, in which case DC control is fine.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/241874-corsair-fan-question/#findComment-3315156
"Good" and "Corsair" when talking about fans are too words that shouldn't be used in the same sentence.
Also yes, get them down to 1450 RPM.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/241874-corsair-fan-question/#findComment-3315164
Can you undervolt the corsair sp120 pwm high performance to be as quiet and as good as the corsair sp120 pwm quiet edition?
If you are gonna run them at that speed you may aswell get the QE's. Or just get quieter fans
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/241874-corsair-fan-question/#findComment-3315174
