Enthoo Pro fan configuration
Solved by rentaspoon,
That should be fine, I'd remove the middle HDD cage if you don't need it as wellOk thanks for all the help guys. Ill probably go for dual 140mm in the front and fill one of the mounts at the top.
5
popularlion ·
Posted in Troubleshooting3 -
1
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1 -
BoBo6107 ·
R_public ·
Posted in Networking14 -
apoyusiken ·
Posted in PC Gaming5
