Adaptive CPU voltage not working
Go to solution Solved by the pokemon kid,
This has been solved now!
It is to do with the power plans which Microsoft has within windows. If it is set to High performance it will pin the CPU at the maximum CPU voltage allowed and try to reach the desired core speed... however if it is set to Balanced it will allow the core voltage and core speed to move adaptively!!!
Hi Guys,
I was wondering if anyone knew what might be going on with my processor and the power it is using...
I have a 4770k and I have had it running at 4.6ghz on 1.200v for quite a while. I have been using adaptive voltage and it has been happily moving its core voltage up and down depending on how much use it has for the last couple of weeks.
I decided to try and overclock my RAM earlier and now, the adaptive voltage wont move at all on CPU-Z. It constantly just sits at 1.200v and is at 31 degrees c constantly... even when it is idle. I have taken the RAM overclock off and cant get the adaptive voltage to come back... :(
https://linustechtips.com/topic/241385-adaptive-cpu-voltage-not-working/
31c idle is normal...
My system usually normally idles at around 26-28c, but still... My core voltage isnt moving adaptively and neither is my core speed...
Awesome!
Don't forget to mark the topic as solved :)
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
