I have been looking but can't find what I'm after.
I have a case with 7 fans (3pin) and 2 cpu (4pin pwm) fans in push pull, and I want to set the system so only 2 case fans run when system is idle and instead of ramping up speeds I can just get the other fans to come on at low rpm in general use and then if really needed at high temps they will start to follow a temp/speed curve.
All the controllers I have seen don't seem to have the capability.
I was thinking I might have to get the soldering iron out and make one, but a nice fancy controller will touch screen and good display would be preffered.
I rather the geek chic then a clever messy project board.
And no, other cooling solutions or cases are not possible this is what I'm stuck with.
https://linustechtips.com/topic/241028-a-real-fan-control-unit/
How about buying an ASUS motherboard with fan xpert 3?
It is far superior to any other kind of fan control on the market.
https://linustechtips.com/topic/241028-a-real-fan-control-unit/#findComment-3303860
https://linustechtips.com/topic/241028-a-real-fan-control-unit/#findComment-3304152
My z77 can shut off fans. Anyway my controller sucks, bought a 20 buck on from micro center. Still works and all but 2 leds out of 6 have quit working. Just got my 2000 rpm noctuas and they wont run on the units lowest setting.
I would go on newegg and get whatever has the best rating and costs $50 minimum.
https://linustechtips.com/topic/241028-a-real-fan-control-unit/#findComment-3307958
With those requirements you are basically looking at two options.
1. Get a fan controller with manual knobs, and manually change the fans to desired speeds. (Something like this: http://www.lamptron.com/product/controllers/fc5-v2/)
2. Go with a more expensive fan controller like something from AquaComputer. This will certainly give you the setup you would like, but it will cost you a good bit. (Like this: http://shop.aquacomputer.de/product_info.php?products_id=3093)
Aquacomputer has some older and cheaper controllers that may be able to do what you want too, I would have a read through their descriptions of each and see which features you want/need.
https://linustechtips.com/topic/241028-a-real-fan-control-unit/#findComment-3308056
