I Was wondering what would be the best way to go abouts buying my graphics cards, i was going to get two GTX650 TI Boosts ( One at a time ) then i looked into it and i could spend 30$ more/ card and get some gtx660's in sli, which would have the better performance, is it worth the extra money?
Computer Eqiupment:
https://linustechtips.com/topic/24102-gpu-help/
660's are the better route.
https://linustechtips.com/topic/24102-gpu-help/#findComment-305431
Sweet, thank you guys :)
Computer Eqiupment:
https://linustechtips.com/topic/24102-gpu-help/#findComment-305458
660s are indeed the better route.
https://linustechtips.com/topic/24102-gpu-help/#findComment-305523
