I want to build my own pc. This is my first time so I need some help. I have put together what I think is a computer that should fit my needs. I plan on gaming a small bit, not an extreme amount, watching movies, browsing the internet, and doing school work. As Im only in high school, my budget is very small. I'll post a link to a part list. Any suggestions on things I coould change or improve on, or just overall tips would be very much appreciated.
Thanks.
http://pcpartpicker.com/user/ChipDorito/saved/MGyH99
https://linustechtips.com/topic/240708-first-custom-built-budget-pc-need-help/
Thanks.
not bad... i will try and see if I can do something more chaper and better.
The blood on to your heart start pumping faster when you notice me.
But is ok.
Judge me for my nickname, my avatar and for the low amounts of posts I have. I will keep your heart beat raised.
Thanks.
here..
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($48.99 @ Mwave)
Memory: Team Elite Plus 8GB (2 x 4GB) DDR3-1333 Memory  ($65.99 @ Newegg)
Video Card: XFX Radeon R9 270 2GB Double Dissipation Video Card  ($139.99 @ NCIX US)
Case: Azza CSAZ-206 ATX Mid Tower Case  ($24.99 @ Newegg)
Total: $427.22
Generated by PCPartPicker 2014-10-28 20:39 EDT-0400
But is ok.
Thanks.
Where do you live? What is the maximum budget? What do you need in the way of peripherals, monitors, OS?
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($59.99 @ Micro Center)
CPU Cooler: Enermax ETS-N30-TAA 50.8 CFM CPU Cooler  ($19.99 @ NCIX US)
Motherboard: Gigabyte GA-B85M-D2V Micro ATX LGA1150 Motherboard  ($49.79 @ Newegg)
Memory: Team Elite 8GB (1 x 8GB) DDR3-1600 Memory  ($62.99 @ Newegg)
Case: Silverstone PS09B MicroATX Mid Tower Case  ($29.99 @ Newegg)
Case Fan: Apevia CF4S-BK 25.6 CFM 80mm  Fan  ($2.07 @ Newegg)
Case Fan: Zalman F2 Plus (SF) 92mm  Fan  ($3.83 @ NCIX US)
Other: Silverstone CPF02 ($6.99)
Total: $449.63
Generated by PCPartPicker 2014-10-28 21:14 EDT-0400
I live in the US. Budget is probably aroud $500. I belive we have an extra monitor lying aroud the house until i can et a better one. My mom said the company she works for coild probably give me a OS for a discount or free.
Very nice, I've done a spec for you in that post.
This is the most budget gaming pc with best perf per dollar. Unlocked pentium g3258 so you can overclock easily, also I left the case empty for you're choice. 8 gb of ram would help to.
http://pcpartpicker.com/p/3xLqwP
Pentium G3258
GTX 750 Ti
4 gb G.Skill Value Ram 1600 mhz
CX430 PSU
1 TB HDD
