So i have decided to get a new phone, specifically a phablet. I am currently using a moto g (1st gen) and am really starting to dislike the small 4.5" screen. After using a friends Galaxy note 3 i absolutely loved the large screen and have hence decided to get something a little bit bigger. I will need to buy my phone unlocked and off contract as I currently h=hav a phone plan (sim only though). My budget is around $400 AUD.
The two phones I have been looking at the HTC One Max ($450) and the sony Xperia Z ultra ($400). I am leaning towards the One because of the front facing speakers and aluminium constriction, and I think the 6.4" Z ultra might be bit to big for me.
So can anyone help me choose, or suggest alternative devices?
Also known to his peers as Lord Scrubby McScrubington
https://linustechtips.com/topic/239721-help-choosing-a-new-phablet/
If you can get the Google play edition of the Z ultra, then i'd get that, but if not then the One. There is nothing wrong with the regular Z, its just that GPE devices get more updates and tend to run better.
OnePlus One or Note 4 would be a good choice.
My PC: Intel Core i3-3220 | Alpenföhn Civetta | XFX HD 7770 1GB | ASRock B75-Pro3-M | Kingston HyperX Blu 8GB | beQuiet PurePower L8 430W | Seagate Barracuda 7200.14 1TB | Kingston V200+ 60GB | NZXT Vulcan | Soundblaster Play Replaced by Notebook + eGPU
My Notebook:   Apple MacBook Pro Retina 13-inch, Late 2013; Core i5 4258U @2.4-2.9 Ghz, 8GB RAM, 256GB PCIe SSD, Iris Graphics 5100 + GTX 960 eGPU
My Phone: OnePlus One with CM12      Camera: Nikon D3200 + 50mm f/1.8G + Kit lenses
I'd choose the HTC One Max out of those two, i do have to warn you that a device this big will mean that using it one handed will be tough and it probably won't fit too well in your pocket. The Sony beats the HTC with specifications, but don't get me started on how massive that screen is for a 'smart'phone.
The Oneplus is a fantastic device, but probably not available to you. And the Nexus 6 would be the best device to suit your needs when it comes out, but it might be out of your price range.
Asus B85M-G / Intel i5-4670 / Sapphire 290X Tri-X / 16GB RAM (Corsair Value 1x8GB + Crucial 2x4GB) @1333MHz / Coolermaster B600 (600W) / Be Quiet! Silent Base 800 / Adata SP900 128GB SSD & WD Green 2TB & SG Barracuda 1TB / Dell AT-101W / Logitech G502 / Acer G226HQL & X-Star DP2710LED
Regular Z Ultra is on KitKat which is not shabby at all, and it's for sure going to get an update to Lollipop. The Sony UI skin is also very light, there's little to no performance loss compared to AOSP.
"Rawr XD"
To the people recommending op a OPO, I recommend reading what he said about phones that are bigger then a Note 3, which means screen size, not overall footprint
Computer Specifications:
AMD Ryzen 5 3600  Gigabyte B550M Aorus Elite | ADATA XPG SPECTRIX D50 32 GB 3600 MHz | Asus RTX 3060 KO Edition CoolerMaster Silencio S400 Klevv Cras C700 M.2 SSD 256GB
1TB Crucial MX500 | 1 TB SanDisk SSD Corsair RM650W
Camera Equipment:
Camera Bodies:
Olympus Pen-F Panasonic GH3 (Retired)
Lenses:
Sigma 30mm F1.4 | Sigma 16mm F1.4 | Sigma 19mm F2.8 | Laowa 17mm F1.8 | Olympus 45mm F1.8 | Panasonic 14mm F2.5
