Skyrim modding noob needs some help
Go to solution Solved by RatedBlam,
In the zip there seemed to be an .esp and a .bsa.
So those would just go to the skyrim data folder.
Most mods do support installation by nexus mod manager or ModOrganizer(more powerful, but maybe not so easy to use)
That'd ease installing and managing mods.
So I recently started playing Skyrim on PC (after playing on ps3) so I started modding like.. Today.
Anways, I wanted to install this mod, but I just don't know how to install it..
I installed SKSE, as they told me to and I also installed SkyUI, as SKSE told me to.
Anyways, both installs went fine but I'm just left here thinking "what should I do to install this mod.."
Any help would be appreciated
https://linustechtips.com/topic/239459-skyrim-modding-noob-needs-some-help/
Stock coolers - The sound of bare minimum
Thanks a lot :D
I needed to know where to put those mod files and now it works !
If you want to know more, Gopher has an excellent Beginner's Guide to Modding Skyrim series https://www.youtube.com/playlist?list=PLE7DlYarj-DdhDG41roBVJfNCqvO5MmKP
He also has a series of Mod Organizer guides https://www.youtube.com/playlist?list=PLE7DlYarj-DcLS9LyjEqOJwFUQIIQewcK
