CPU Power Cable Extenstion?
By
Raudi_
in Power Supplies
in Power Supplies
Solved by LukaP,
So I just ordered 3 of these:http://www.newegg.com/Product/Product.aspx?Item=12-493-119
2 of them are got my 770's
Would it hurt to use 1 of them as a CPU power cable?
notice the different shapes, so as @TheSLSAMG said, no it wont fit
(edit, actually it seems to fit, but you would put voltage through the ground pins, shorting your cpu, killing everything, so dont do it)
3
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases5 -
2
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18
play_circle_filled
Latest From ShortCircuit:
