NZXT Phantom 410 Led color change?
Plain
I Have a NZXT Phantom 410 and I'm wondering if it's possible to be able to change the color of the LED lights? If so i'll be painting it and completely change it!
If the LEDs are in the fans you could probably just buy new fans
PC Spec/ Peripherals: AMD FX-8320 3.5GHz (OC @ 3.8GHz) - CoolerMaster Hyper 212 Heatsink - ASRock 970 EXTREME3 Motherboard - G.SKILL Ares Series 16GB 240-Pin - Sapphire Vapor-X Radeon HD 7950 3GB - Western Digital 1TB HDD (Caviar Black) - Corsair CX600 600w PSU - CoolerMaster Storm Scout Case - Razer Naga Gaming mouse - Razer Blackwidow Ultimate Mechanical Keyboard
^This if there's only fan mounted leds, or alternatively your only other option would be soldering in new ones which is relatively simple. I found this guide here, haven't really looked through it myself but it looks to be similar to what you're talking about.
http://www.overclock.net/t/1032225/guide-for-swapping-leds-on-the-nzxt-phantom-fan-controller
Or maybe a NZXT HUE (RGB LED color controller and I think 2 metres strip of LEDs)
