So I added my mixture in my loop and it was a bright red but once it got inside loop it turned a darkish ugly red so I wanted to know did I do something wrong I mixed it with distilled water and i used mayhems pastel red here are pics of coolant and loop
post-13632-0-76941700-1414100288_thumb.j
System Specs~~~~~
Case-Corsair Air 540                                   CPU-i7 4770k                           Ram-Corsair Vengeance 16 Gbs    PSU-Corsair RM1000
Motherboard-Asus Maximus VI Formula    Graphics-Asus Gtx 780 Ti x2     CPU Cooler-Corsair H100i               SSDs-Corsair Force GS 128/360 Gb
https://linustechtips.com/topic/237923-loop-color-problems/
Can't upload picture of loop says file to big even tho took it with phone
System Specs~~~~~
https://linustechtips.com/topic/237923-loop-color-problems/#findComment-3262832
upload it to imgur and then link the pic
or compress the image
or use a different image format
https://linustechtips.com/topic/237923-loop-color-problems/#findComment-3262922
What kind of tubing are you using PrimoFlex Advanced LRT Tubing by any chance?
yes I am why
System Specs~~~~~
https://linustechtips.com/topic/237923-loop-color-problems/#findComment-3263125
System Specs~~~~~
https://linustechtips.com/topic/237923-loop-color-problems/#findComment-3263156
Some of the chemicals used in that tubing reacts with some dyes. Perhaps this is your issue?
posted pics
System Specs~~~~~
https://linustechtips.com/topic/237923-loop-color-problems/#findComment-3263158
than why do some people have the nice bright red that I want wit primo tubing ugh this sucks do u know any tubing that doesn't have this issue??
System Specs~~~~~
https://linustechtips.com/topic/237923-loop-color-problems/#findComment-3263290
