Run anit virus scan, sounds like adware. Not too sure what you would use to remove that but removing tool bars can be done by using CCleaner (afaik)
https://linustechtips.com/topic/237641-addspop-ups-help-me/#findComment-3258764
somebody's been clicking all the wrong stuffs :P
Adware plus & malwarebytes sweep should do the tricks, make sure you scan for pottential unwanted programms, (pup enabled) when scanning..
Details separate people.
https://linustechtips.com/topic/237641-addspop-ups-help-me/#findComment-3258851
