Seidon 120V with AMD 8350 temps
Hi Guys/Gals
For my first real post on the forums I figured I'd ask for some advice.
I'm using a Seidon 120V for my AMD 8350 Black Edition.
The temps are usually around 30-35 C at idle and can get up to 50C at heavy load.
I've got it in a push/pull on the back of my case, SP fan pushing and AF fan pulling.
When I first built the machine a few months ago the idle temps were about 15C and it rarely went over 25C
Should I be worried about the cooler not functioning fully, or am I just being too paranoid about temps?
I know the chip can take the heat and its hardly like I'm frying it, (my older intel quad core ran at 100C for a few years using a stock fan, and still does run, but at much lower temps with a new fan installed)
What I'm worried about is that a few months ago it was at 20C mark, now its closer to 40C.
Any advice would be much appreciated.
I have the same setup and the same temps, the single rad setup is not the best hence the budget temps
