No. You would need to plug the fans directly into the GPU which would require a bit of modding.
What you can do though is link the fan speed to the PCIe temp sensor (if you have one on your motherboard) and that should heat up linearly according to your GPU temperature.
https://linustechtips.com/topic/236999-fan-control/#findComment-3249723
It might be doable with SpeedFan--not too familiar with it though considering the UI isn't the friendliest.
https://linustechtips.com/topic/236999-fan-control/#findComment-3272382
