Alright my aunt is having problems and she lives in a different state so i just can't drive over there but teamviewer is so nice.
I have told her to unplug everything that she does not use, so the only things that are plugged in are the mouse, keyboard, and monitor
She has not installed anything new, which makes me think its her RAM and i have run malwarebytes and microsoft essentials and nothing comes up.
I have the HTML file attached and I have a text file as well.
report.html
bluescreens.txt
Thanks to anyone that can help.
https://linustechtips.com/topic/23698-bluescreen-problems/
Ye it is a good idea to run memtest if you think that may be the problem. It is best to eliminate possible causes of problems as you go along.
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
https://linustechtips.com/topic/23698-bluescreen-problems/#findComment-300346
