ZOTAC 970 Card Dimensions
Solved by Rheinwasser,
That isnt what Im worried about, Im worried about how close its going to be to the side panel of the case.
-snip-
its not wider than the pcie slot.
that means that there as much space between gpu and side panel as corsair left. that is about 2-3cm.
Featured Topics
IR76 ·
Posted in Networking2 -
Blasty Blosty ·
Posted in Audio6 -
c0mplexx* ·
Skelitor ·
Posted in General Discussion6 -
1
4
11
13
