Gigabyte GTX 970 Windforce G1: 15.9" or ~400mm
Corsair 200r Supports up to: 420mm.
Yes it will fit.
https://linustechtips.com/topic/236644-does-it-fit/#findComment-3243911
Yes it will fit.
420mm. ayyy measure it. ;) ;)
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/236644-does-it-fit/#findComment-3243972
Corsair 200r Supports up to: 430mm.
Yes it will fit.
fixed
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
https://linustechtips.com/topic/236644-does-it-fit/#findComment-3244000
fixed
Corsairs website said 420mm..
https://linustechtips.com/topic/236644-does-it-fit/#findComment-3247765
well pcpartpicker says otherwise
https://linustechtips.com/topic/236644-does-it-fit/#findComment-3247790
1 will fit, 2 may not.
Also it would be really nice if Newegg could post correct data once and a while. Especially since everyone seems to go there instead of manufacturer websites for info.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/236644-does-it-fit/#findComment-3247846
I doubt corsair would put the wrong specs on their website.
http://www.corsair.com/en-us/carbide-series-200r-compact-atx-case
Maximum GPU Length
420mm
https://linustechtips.com/topic/236644-does-it-fit/#findComment-3248442
Maximum GPU Length
420mm
well either way it still should fit
https://linustechtips.com/topic/236644-does-it-fit/#findComment-3248446
