I have a hyper 212 evo and an amd fx 8350 going in a haf 922 case, it has a back exhaust as well as a top fan. should i put the cpu fan blowing to the back and pusing air through heatsink/pulling through heatsink.
or have it push/pull to the top of case?
thanks alot guys. And the part about whether i should push or pull through heatsink is important as well
https://linustechtips.com/topic/23549-which-orientation-for-cpu-fan/
As far as I know, it comes preattached in a push setup. Unless you have RAM clearance issues (like my friend did), don't bother switching the position, it makes no difference performance-wise. Aesthetically, I prefer the look when it's in push.
Wit is educated insolence.
would you reccomend out the back or out the top
Uhh, not sure if it makes any difference in performance. Again, aesthetically, I think I'd prefer out the back.
If you have a graphics card in the first PCI-E slot, then the fan might be SLIGHTLY starved for air if you're pushing up, but I can't imagine it making too much of a difference.
