Quick question about fan controllers
If I was planning on getting a fan controller to well, control my fans, could I use a 3 pin splitter to hook up 2 fans to 1 channel? Could I, hypothetically, repeat this, plugging splitters into splitters, as long as the channel supports the wattage of the fans I eventually plug in?
https://linustechtips.com/topic/235335-quick-question-about-fan-controllers/
You should be able too, but is probably not recommended.
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
Most fan controllers are usually made to power 2 maybe 3 fans with spiltters at most, I don't think you'll be able to find a controller that can supply that much wattage. It could just end up breaking the controller.
But as long as the fan wattage max is lower than the channel's wattage, it will be ok, right?
MOST
Most likely.
Yes.
Just make sure you do your math right, and leave a bit of extra wattage room for error.
Also when motors start up from being still they will take a surge of power approximately 1.5x that of the rated continuous wattage.
