Right Case
Solved by Thorium19,
For the best airflow outright, don't look further than the silverstone RV/FT05. They're the best air cooling cases out there, proven. Only issue really is the PSU accommodation if you want a 3.5" hdd rack.
Other cases I would recommend are the corsair air 540, as it's got a twin chamber design for better cooling, and is fairly effective.
The NZXT phantom 410 is decent for cooling, but looks pretty bad in certain colours (plastic and paint not matching) and lacks dust filters.
