MSI 970A-G45 help
Go to solution Solved by i_build_nanosuits,
I would like to know how many fan headers dose it have, and how good is the over clocking on it with a 6300 cpu
this board as a cheap 4+1 VRM and no heatsink...it's really not designed to overclock the FX-6300 at all...period.
You don't want to run a 6300 on this board. Like other low-end MSI boards before it, this one has a weak VRM setup that is known to fail easily.
The cheapest motherboards that can successfully (and safely) overclock FX CPU's are gigabyte 970A-UD3P, ASUS M5A97 EVO and MSI 970 Gaming.
Main: i7 2600 | ASUS P8Z68-V | 2x4GB Vengeance 1600 | GTX 580 | WD Blue 1TB | Antec TP-650C | NH U12S | W7 x64
Backup: X6 1090T | MSI K9A2 Platinum | 4x2GB XMS2 800 | GTX 550Ti | WD Blue 1TB |  Antec VP-450 | CM TX3 | W7 x64
https://linustechtips.com/topic/234773-msi-970a-g45-help/#findComment-3215458
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/234773-msi-970a-g45-help/#findComment-3215649
