My Build Plan
Go to solution Solved by brob,
Would you be able to provide a link to what you would recommend since I am very new to all this?
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($175.00 @ PCCaseGear)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($39.00)
Motherboard: Asus M5A99X EVO R2.0 ATX AM3+ Motherboard  ($159.00 @ PCCaseGear)
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1866 Memory  ($105.00 @ PCCaseGear)
Storage: Intel 520 Series Cherryville 120GB 2.5" Solid State Drive  ($79.00 @ PCCaseGear)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($65.00 @ PCCaseGear)
Video Card: Gigabyte GeForce GTX 770 4GB WINDFORCE Video Card  ($399.00 @ PCCaseGear)
Case: Corsair Graphite Series 230T Black ATX Mid Tower Case  ($95.00 @ PCCaseGear)
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($99.00)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($115.00 @ PCCaseGear)
Other: ASUS DRW-24D3ST 24x DVD Writer ($20.00)
Total: $1350.00
Generated by PCPartPicker 2014-10-16 17:20 EST+1100
Hi guys, so I have got a build plan from someone and I have made a few alterations to it and wanted finial thoughts on it. Haven't been able to list it on pc picker since they don't seem to have all the parts.
Monitor-Acer K242HL 24in LED Widescreen Monitor
Ram-Kingston Hyper X Fury HX316C10FBK2/8 8GB (2x4GB) Black
Psu-Silverstone Strider Essential 600W ST60F-ESB
GPU-Gigabyte GeForce GTX 770 OC Edition 4GB
HardDrive-Western Digital WD Blue 1TB WD10EZEX
SSD-Samsung 840 EVO Series 120GB SSD (Just For Windows 8)
CPU-AMD FX-8320 8 Core Black Edition Processor
MotherBoard-ASRock 970 Extreme4 Motherboard
Case-Corsair Carbide SPEC-01 Mid Tower Gaming Case
DVD Driver-ASUS DRW-24D3ST 24x DVD Writer
Fan-Corsair Air Series AF120 Quiet Edition Red LED Fan (Will go at back)
OS- Windows 8.1 64bit
I can include keyboard etc if you want. Haven't listed prices since I am on a ipad. Can list prices if wanted. Oh and this is a Australian build.
https://linustechtips.com/topic/233808-my-build-plan/
The memory kit is not optimal. DDR3-1600 kits with CAS 9 are better choices.
The psu is not a good choice.
An aftermarket cooler is needed if the FX-8320 will be overclocked. A better motherboard would also be a good idea.
An IPS panel monitor will provide better color reproduction and wider viewing angles.
https://linustechtips.com/topic/233808-my-build-plan/#findComment-3195035
https://linustechtips.com/topic/233808-my-build-plan/#findComment-3195051
The AMD 290 might be a better bet instead of that 770.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/233808-my-build-plan/#findComment-3195054
This do you?
CPU Cooler: NZXT Respire T40 68.8 CFM Sleeve Bearing CPU Cooler  ($29.00 @ PCCaseGear)
Motherboard: Gigabyte GA-970A-D3P ATX AM3+/AM3 Motherboard  ($109.00 @ Mwave Australia)
Memory: GeIL EVO Veloce Series 8GB (2 x 4GB) DDR3-1600 Memory  ($79.00 @ PLE Computers)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($64.00 @ Centre Com)
Video Card: Asus Radeon R9 280 3GB DirectCU II Video Card  ($249.00 @ Scorptec)
Case: Zalman Z3 Plus ATX Mid Tower Case  ($59.00 @ Mwave Australia)
Optical Drive: LG GH24NSB0 DVD/CD Writer  ($19.00 @ PCCaseGear)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($115.00 @ Centre Com)
Monitor: LG 23MP55HQ-P 60Hz 23.0" Monitor  ($186.00 @ Mwave Australia)
Case Fan: Gelid Solutions FN-SX12-10 37.0 CFM 120mm  Fan  ($6.00 @ PCCaseGear)
Total: $1206.00
Generated by PCPartPicker 2014-10-16 16:45 EST+1100
https://linustechtips.com/topic/233808-my-build-plan/#findComment-3195057
Total: $1350.00
https://linustechtips.com/topic/233808-my-build-plan/#findComment-3195161
Total: $1350.00
Thank you! I thiugh everyone had abandoned me.
https://linustechtips.com/topic/233808-my-build-plan/#findComment-3195169
https://linustechtips.com/topic/233808-my-build-plan/#findComment-3195200
