I just started using premier pro and I render out a video at 1080p at 16 bit color and I dont know anything about video rendering or premier pro for that matter but which codec should I be using and what are the optimal setting for a video to render out 1920x1080 at 16 bit color and come out at a moderate file size? I dont care about render times because I have patience and I am willing to wait for a good quality render. On top of that I am going to be uploading it to Youtube so since youtube compression is terrible and makes the video come out like crap how can I optimize my video to look the best?
https://linustechtips.com/topic/233755-premier-pro-optimal-render-setting/
AVI is the best, but it makes huge files that will take you days to upload to youtube unless you have gigabit internet.
Render in H.264.
See the attached for my render settings. Its based on a youtube video "YouTube Compression - The battle for quality with slow internet." ,but I made several adjustments.
You may wanna tick "Render at maximum depth" and maximum render quality" and change Bitrate encoding to VBR 2 Passes.
Unless Youtube re-encodes videos to Webm/.VP9 (Only for videos with high view counts I observe, I could be wrong), videos with low view count will be stuck with mp4/.avc (which looks like crap as you said).
Imo, due to Youtube sucky compression for mp4/.avc , I have yet to see any differences between 8Mbps and 30Mbps bitrates.
Examples of my recent videos rendered in this setting
