Quick question about radiator fans
Go to solution Solved by FizzyFantom,
I don't see a problem in this, it can't hurt. Even if that case fan isn't designed for Radiators, it can still help a little bit.
I have encountered issue with mismatched fans. The case fan will impede airflow through the radiator rather than increasing it and the other fan would be required to have a greater static pressure to move the air through the rad an the fan together.
OP, it isn't advisable to use mismatched fans in push pull as the airflow and static pressure of the fans would likely be different. You may find that the other fan makes no difference or even reduces the efficacy of the cooler, but it won't hurt to try it. I suggest you test it out to see if it makes a noticable difference.
Here's the deal:
I currently have this as my CPU cooler: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103195
and I happen to have this as my extra fan: http://www.deepcool.com/product/dcoolingaccessory/casefan/2013-12/47_623.shtml
I plan to put the radiator in a pull setup, where the fan serves as an exhaust, pulling air out of the case.
Outside < Fan < Radiator
Question: Is it okay for me to use the extra fan to make a push-pull setup? I have it lying around and didn't want it to be wasted. So it'll be like:
Outside < Radiator Fan < Radiator < Case Fan
Noob here. I'm still new to all this and I'm just looking at this in terms of not wasting any fans.
CPU: Intel® Core™ i7-4770 Processor (8M Cache, up to 3.90 GHz) CPU Cooler: Cooler Master Seidon 120V Mobo: ASUS B85M-G RAM: Kingston Technology HyperX 16 GB Kit (4x4 GB Modules) 16 Quad Channel Kit 1600 GPU: XFX Radeon HD 7850 Case: DeepCool Tesseract SW Storage: WD  1TB PSU: Cooler Master V650
https://linustechtips.com/topic/233404-quick-question-about-radiator-fans/
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
"PSU brands are meaningless, look up the OEM."
As long as you're using the same fan for push/pull, you're fine.
Bert & Ernie before squirting spermie.
So I take it that, it's better to have the SAME fans if I'm planning on doing push pull?
Yes, because if one fan is stronger than the other this will have adverse effects on the weaker fans. With adverse effects being shorter life span, annoying noises from increased stress on the motor or bearing and worst-case scenario the fan breaks.
