Fan controller
Go to solution Solved by spwath,
Just drove to frozen CPU and picked up 2 of the phobya's. They feel and look pretty good
@TheProfosist
Im loking to get a fna controller with 2 seperate chanels for under 15$
Would 2 of these be the best? http://www.frozencpu.com/products/984/bus-08/Zalman_FAN_MATE_2_Variable_Speed_Fan_Controller_FanMate-2.html
Must be avalible at frozencpu, be under 15$, not take a 5.25 inch bay, and have 2 chanels. I guess it can take a 3.5 inch bay, but id rather it not.
https://linustechtips.com/topic/233115-fan-controller/
Why not use the mb headers?
non PWM fans
Why you dont want a face fan controler?
No 5.25 inch bays in my case
^ this with PWM fans and you are set
No PWM fans
Anything has two channels...
https://linustechtips.com/topic/233115-fan-controller/#findComment-3185556
Grant us the joy of song and dance and ever watch over us in the lonely places in which we must walk - Pray to Bastet
https://linustechtips.com/topic/233115-fan-controller/#findComment-3185601
Could work, dont really need USB, and would perfer non 3.5 inch. Might get it.
https://linustechtips.com/topic/233115-fan-controller/#findComment-3185617
I wonder what kinda case you have and has no 3.5 or 5.5 e_e
Also, H440
https://linustechtips.com/topic/233115-fan-controller/#findComment-3185667
@spwath If you want one of the ones in the OP I have a few around here as Zalman use to throw them at you whenever you bought anything from them.
I also have some inline resistors that might accomplish what you want.
https://linustechtips.com/topic/233115-fan-controller/#findComment-3185680
Also @spwath the one in teh OP just does one fan unless you split it and needs to plug into a MB header unless you have an adapter to molex.
https://linustechtips.com/topic/233115-fan-controller/#findComment-3185691
Also, H440
Oh you want a quite case? Why not try Aerocool DS 200 it is also noise isolated and has a fan controller from stock
https://linustechtips.com/topic/233115-fan-controller/#findComment-3185695
Would you give them to me?
Ik, look:
No, i want a nice case. A silverstone case.
https://linustechtips.com/topic/233115-fan-controller/#findComment-3185738
https://linustechtips.com/topic/233115-fan-controller/#findComment-3185762
Ik, look:
I can give you a few resistors yes but not the fan controllers. I can however sell them to you cheaper than FrozenCPU.
But I do have the same question as @nanowatt why not just use the MB fan headers?
https://linustechtips.com/topic/233115-fan-controller/#findComment-3185788
https://linustechtips.com/topic/233115-fan-controller/#findComment-3185794
I have some resistors.
Not pwm fans.
I'll get the other one I linked, all sleeved up nice
https://linustechtips.com/topic/233115-fan-controller/#findComment-3185814
It says:
"The voltage is adjusted with a small potentiometer and the unit draws power via a 3-Pin connector. With adapter cables, even more possibilities can be found for connection of the unit. "
So how small is that potentiometer because I dont see it in any of the pics.
https://linustechtips.com/topic/233115-fan-controller/#findComment-3185828
Not pwm fans.
Most on baord fan controller do both PWM and voltage control. Or many time ones the CPU header does PWM and the chassis ones are still voltage control.
https://linustechtips.com/topic/233115-fan-controller/#findComment-3185849
Mine only has 1 voltage control
https://linustechtips.com/topic/233115-fan-controller/#findComment-3185867
It says:
Their pics are wrong, and if you click the zoom in thing it does the potentiometer. Google shows it to
https://linustechtips.com/topic/233115-fan-controller/#findComment-3185874
Split it off unless you need to control them independently. Also heres the correct pic for that device. Its basically the same as the zalman but sleeved http://goo.gl/dxGXzp .
https://linustechtips.com/topic/233115-fan-controller/#findComment-3185877
I think it's exactly the same but sleved. I want them separate as my aerocool is much louder than my ap123 at 12v
https://linustechtips.com/topic/233115-fan-controller/#findComment-3185886
