In my knowledge i-series (Insomnia) is biggest held in UK. Above is good collection of others, which of I've heard about Epiclan. Surprisingly quick Google search brought several sites worth checking out for finding parties in your area. Most seems to be bit out of date, but at least you will get links where to look for.
There might not be anything in your general area (bit like in here) but some travelling will get you either into the big ones or take a look of one of the smaller ones.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/232299-lan-parties-in-uk/#findComment-3175817
i believe there is a monthly one at Loughborough Uni or at least a regular one (I have a friend who goes there, the Uni and the Lan party)
Intel Core i5 4690K @ 4.2Ghz | Evga GTX 780 Ti SC ACX with backplate | MSI Gaming 9 AC | 8GB (2x4) Corsair Vengeance Pro Silver 2400 MHz | Corsair H105 128GB Crucial MX100 | Toshiba 2TB | Evga 750G2 | Corsair Obsidian 750d | Be Quiet Silent Wings 2 PWM (3x140mm & 3x120mm)
https://linustechtips.com/topic/232299-lan-parties-in-uk/#findComment-3175823
