Crossfire Help!
Go to solution Solved by JefferyD90,
No to crossfire a 280 you need another r9 280 or what ever the 280 is a refresh of (7950 i think)
not entirely correct.  you can use any GPU that uses that same core design.  The R9 280 should be able to crossfire with a R9 280, R9 280X, HD7950, HD7970, and any of their variants.  There may be another card that doesn't come to mind right off hand, but its called Tahiti.  So go look that up, anything based on Tahiti will crossfire together.
Nvidia is to Dr Dre Beets as AMD is to KFC.
One makes you broke, the other you can get more of and have a midnight snack from the fridge when hungry again. Once you go Nvidia, you go broked, turn into an Elitist, or get the incorrect amount of VRAM.
- WCCFTECH
 I was only 9 years old. I loved Fifflaren so much, I had all the NiP merchandise and matches pirated. I prayed to Fifflaren every night before bed. Thanking him for the life I have been given. Fifflaren is love I say. Fifflaren is life. My dad hears and calls me a fuckhead. I knew he was just jelly of my passion for Fifflaren. I called him a Sw@yer. He hits me and sends me to go to sleep. I'm crying now, and my face hurts. I lay in bed and it's really cold. A warmth is moving towards me. I feel someone touching me. I feel someone touching me. It's Fifflaren. I am so happy. He whispers in my ear; "this is my pyjama". He grabs me with his powerful Swedish hands and puts me on my hands and knees. I'm ready. I spread my ass cheeks for Fifflaren. He penetrates my butt-hole. It hurts so much but I do it for Fifflaren. I can feel my butt tearing as my eyes start to water. I push against his force. I want to please Fifflaren. He roars a viking roar as he fills my butt with his love. My dad walks in. Fifflaren looks straight into his eyes and says; "He is a ninja now". Fifflaren is love, Fifflaren is life
https://linustechtips.com/topic/232226-crossfire-help/#findComment-3174424
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/232226-crossfire-help/#findComment-3174440
Yeah i forgot about that but to me it seems a bit weird to do it.
- WCCFTECH
https://linustechtips.com/topic/232226-crossfire-help/#findComment-3174451
When you look at these different GPU's don't look at them as completely different GPUs.  To compare them to cars, imagine a Ford (AMD) Taurus (Tahiti) SE (R9 280) versus a Ford (AMD) Taurus (Tahiti) Touring Sedan (HD7950).  They are the same video card just a few more bells and whistles.  I also looked into the 7870 XT is also a Tahiti core, but I DONT think it is crossfire'able for some stupid reason.  Do you'll need to do some more research on that for me though, cause I'm too lazy to do it.
https://linustechtips.com/topic/232226-crossfire-help/#findComment-3174496
So I am thinking about buying a new gpu for my computer, it currently has a MSI radeon HD 7750, and I am planning on getting an XFX r9 280. Will I be able to run them in crossfire for extra performance.
It isn't worth crossfiring a 7750 with anything except another 7750 and even then if you play older games the problems may outweigh the gains.
A 7870XT can be crossfired with any tahiti core gpu.
Murphy's Law: "Anything that can go wrong, will go wrong"
https://linustechtips.com/topic/232226-crossfire-help/#findComment-3174800
