hi guys! first time builder here.
After months of saving, I finally decide to make myself a nice pc for gaming. no video editing/high resolution photo editing.
http://ca.pcpartpicker.com/user/Frezzx/saved/X4Kscf
any change should be made? what's your opinions?
You are welcome to tweak around it to make it even more optimal. Keep in mind that this is the very top end of my budget.
It is aim to run today's most demanding game at 1080p with decent fps.
Thanks!
https://linustechtips.com/topic/232102-another-1000-build-cad/
CPU: AMD FX-8350 4.0GHz 8-Core Processor  ($187.98 @ DirectCanada)
Motherboard: Asus M5A99FX PRO R2.0 ATX AM3+ Motherboard  ($144.95 @ Vuugo)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory  ($87.62 @ DirectCanada)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card  ($349.99 @ Amazon Canada)
Case: BitFenix Comrade ATX Mid Tower Case  ($42.99 @ NCIX)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.95 @ Vuugo)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($104.98 @ Newegg Canada)
Total: $1067.43
Generated by PCPartPicker 2014-10-12 20:18 EDT-0400
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/232102-another-1000-build-cad/#findComment-3172981
Total: $1067.43
I do like it, but.. no two 120mm case fan in front? will it not overheat?
https://linustechtips.com/topic/232102-another-1000-build-cad/#findComment-3173009
It won't. I advise you invest some more and get a CPU cooler(possibly the Cooler Master 212 EVO,212x or Hyper T4)
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($156.98 @ DirectCanada)
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard  ($114.99 @ NCIX)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1866 Memory  ($89.98 @ Newegg Canada)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($56.98 @ DirectCanada)
Case: BitFenix Comrade ATX Mid Tower Case  ($56.85 @ DirectCanada)
Total: $1025.69
Generated by PCPartPicker 2014-10-12 20:24 EDT-0400
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
https://linustechtips.com/topic/232102-another-1000-build-cad/#findComment-3173027
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($246.98 @ DirectCanada)
Motherboard: ASRock B85 Anniversary ATX LGA1150 Motherboard ($59.50 @ Vuugo)
Memory: Corsair Vengeance LP 8GB (2 x 4GB) DDR3-1600 Memory ($79.99 @ Memory Express)
Video Card: EVGA GeForce GTX 970 4GB ACX Video Card ($369.99 @ Memory Express)
Case: BitFenix Merc Alpha (Black) ATX Mid Tower Case
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply ($69.98 @ Amazon Canada)
Total: $883.42
Generated by PCPartPicker 2014-10-12 20:26 EDT-0400
Anyone who has a sister hates the fact that his sister isn't Kasugano Sora.
Anyone who does not have a sister hates the fact that Kasugano Sora isn't his sister.
I'm not insulting anyone; I'm just being condescending. There is a difference, you see...
https://linustechtips.com/topic/232102-another-1000-build-cad/#findComment-3173031
Total: $1025.69
I can spend a little more for that CPU cooler, thank you for your advise. I'll recheck my build.
https://linustechtips.com/topic/232102-another-1000-build-cad/#findComment-3173046
the case has some stock fans correct
https://linustechtips.com/topic/232102-another-1000-build-cad/#findComment-3173052
Total: $883.42
I do like your build with the i5-4690k and the gtx970, The only problem is the MOBO. I do want to upgrade in the future and maybe even crossFire.
https://linustechtips.com/topic/232102-another-1000-build-cad/#findComment-3173059
PCPartPicker part list: http://ca.pcpartpicker.com/p/cbnyLk
Price breakdown by merchant: http://ca.pcpartpicker.com/p/cbnyLk/by_merchant/
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor ($214.50 @ Vuugo)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard ($69.00 @ Vuugo)
Memory: Kingston Fury Series 8GB (2 x 4GB) DDR3-1600 Memory ($84.99 @ NCIX)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive ($63.98 @ DirectCanada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($53.98 @ DirectCanada)
Case: Corsair 200R ATX Mid Tower Case ($53.98 @ DirectCanada)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($74.99 @ NCIX)
Total: $985.36
Generated by PCPartPicker 2014-10-12 20:34 EDT-0400
Pick yourself up Windows from G2A
Asus MAXIMUS VII Gene 2 x 8GB G.Skill 16GB 1600 Mhz Intel 4670k @ 4.3 Ghz Corsair H100i w/ stock fans EVGA GTX 770 SC Intel 750 Series SSD 240GB, Samsung 840 SSD 240GB WD Caviar Green 2TB Seasonic X-650 V3 2 x 140 mm Noctua A14 PPC, 120mm LED Corsair AF120
https://linustechtips.com/topic/232102-another-1000-build-cad/#findComment-3173083
CPU Cooler: be quiet! Dark Rock Pro 3 93.3 CFM Fluid Dynamic Bearing CPU Cooler  ($69.99 @ Canada Computers)
Motherboard: Gigabyte GA-Z97X-Gaming 3 ATX LGA1150 Motherboard  ($134.99 @ NCIX)
Total: $1018.54
Generated by PCPartPicker 2014-10-12 20:37 EDT-0400
https://linustechtips.com/topic/232102-another-1000-build-cad/#findComment-3173095
Total: $1018.54
I think it's getting there, I might throw over a couple more bucks for an optical drive.
is it worth it to switch over from the Fx-8350 to i5-4690k? (Mobo too)
https://linustechtips.com/topic/232102-another-1000-build-cad/#findComment-3173167
ohh yea it wont bottleneck your gpu and it is faster also it gives you a better upgrade path
https://linustechtips.com/topic/232102-another-1000-build-cad/#findComment-3173173
And why is the cpu cooler provided with the i5-4690k not enough?
((keep in mind i am very new to this :P))
it is just really bad
https://linustechtips.com/topic/232102-another-1000-build-cad/#findComment-3173221
Im still not sure about the case, mostly because there is no USB 3 front panel and i'll have to buy at least one other fan because it only comes with one.
But in the end this is pretty much the perfect build for me!
http://ca.pcpartpicker.com/user/Frezzx/saved/2NkH99
I'll be picking up windows 8.1 64bit OEM on G2A when it will be available
feel free to give your thoughts about it. Thanks for all your feedback.
https://linustechtips.com/topic/232102-another-1000-build-cad/#findComment-3173544
