I am planning on getting some new earphones soon
I have looked at some from Audio technica and some from Sennheiser
Is this any good
ATH-CHX7iS
If not can you advise any other earphones
Thanks
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
https://linustechtips.com/topic/231847-earphone-help-please/
Anything from the big names like audio-technica should be good, so if that's what you think you want then I'll just say go ahead and grab 'em
https://linustechtips.com/topic/231847-earphone-help-please/#findComment-3169725
Any suggestions as to some other nice earphones ?
https://linustechtips.com/topic/231847-earphone-help-please/#findComment-3169758
The Best Earphones Under $50
I'll also recommend the NuForce Ne-600X for super bassy and cheap, or the Soundmagic E10 for a more balanced bassy sound.
https://linustechtips.com/topic/231847-earphone-help-please/#findComment-3169783
Thanks
https://linustechtips.com/topic/231847-earphone-help-please/#findComment-3169787
