Problems with RAM
Hmm that's what i was thinking, windows shows 2133mhz, which i assume would is the speed of the whole kit.
What do you mean? CPU-Z displays 1/2 of the frequency because DDR = double data rate, therefore you take the frequency CPU-Z gives you, and multiply by 2 to get the actual speed the RAM is running at. That's PER stick, not both sticks combined. Both sticks run at 1600 if CPU-Z says the ram is at 800 mhz (not both sticks running at 800 mhz x2 sticks = 1600). (and in my case, 1066mhz in CPU-Z = 2133 for both sticks, not both sticks added together, that's not how it works)
The windows performance manager automatically does the multiplying for you, to make it more "dummy proof."
I'm confused as to why Windows performance manager for you was displaying "800 mhz" when CPU-Z is telling you 800 as well. I would assume it's running at 1600 if the bios says it is.
I'll read your BIOS pictures and see if I notice anything
