that depends on how many sata ports you have on your motherboard.
https://linustechtips.com/topic/231580-storage-problem/#findComment-3166353
I want my ssd to have no raid, does my ssd still work?
yes
https://linustechtips.com/topic/231580-storage-problem/#findComment-3166387
does it still run fast?
yes
What should I do after I done installing my ssd?
you boot into windows and you will see in the 'computer' tab of windows explorer that there is another empty drive there, that is your new SSD.
right click it, format it, and now you can put your files on it.
https://linustechtips.com/topic/231580-storage-problem/#findComment-3166462
yes
If it doesn't show up right away you may need to download a tool to install a special driver, like with my Seagate Barracuda, I had to download a program from them.
Gaming Rig - Excalibur - CPU: i5 6600k @ 4.1GHz, CPU Cooler: Hyper 212 Evo, Mobo: MSI Gaming M3 RAM: 16GB Corsair @2400MHz, GPU: EVGA 1060, Case: NZXT Phantom Full Tower (Red)
My Virtualization Server - Dell R710: 2x X5570s @ 2.93GHz with 32GB DDR3 RAM [Web Server, OSX, Plex, Reverse Proxy]
I love computers, gaming, coding, and photography! Be sure to quote me so I can respond to your post!
https://linustechtips.com/topic/231580-storage-problem/#findComment-3167040
Hard drive don't need drivers, the SATA controller uses a driver though. Some manufacturers supply software that you can use to check how the hard drive is running, but it's not needed to use the drive.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/231580-storage-problem/#findComment-3168584
You don't need driver or programs for a hard drive...
You just need to go into administrative tools and format the drive and assign a letter to it. You can do all this in windows.
https://linustechtips.com/topic/231580-storage-problem/#findComment-3168941
Well at least when I installed my Barracuda I had to install SeaTools, you know what I just thought about that you only need it for hard drives larger than 1tb.
https://linustechtips.com/topic/231580-storage-problem/#findComment-3169367
No...
My 2TB barracuda worked without any software.
I think you only need those tools for booting from drives over 2.2TB
https://linustechtips.com/topic/231580-storage-problem/#findComment-3169373
No...
That's odd with my rigs specs which are in my sig I had to install SeaTools in order to use it as a regular drive. It was a 1.5tb Barracuda.
https://linustechtips.com/topic/231580-storage-problem/#findComment-3169386
Did you format it to the correct storage type NTFS or AHCI?
https://linustechtips.com/topic/231580-storage-problem/#findComment-3169757
It didn't show up in computer right away so I had to install seatools and format it from there. I'm pretty sure it is the same as windows' disk manager thing can't think of the name now.
https://linustechtips.com/topic/231580-storage-problem/#findComment-3169796
