Hello,
I have a i5 4690k, and when at stock, with 2 7950s, they get bottlenecked in bf4 at 60% usage. When I oc it to 4.6ghz, I get 85-95% usage in BF4 64p Rush. Is it normal that in bf4 this i5 will bottleneck?
Thanks
in bf4 it is not likely its probably an optimization issue
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/231300-i5-4690k-help/#findComment-3162913
i had a similar issue with bf4 running 2x7950's cfx
disable cfx and see what your framerates are like with just one card
may be poor cfx optimization by EA or driver issue.
4690k will NOT bottleneck 2x7950 cfx
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
https://linustechtips.com/topic/231300-i5-4690k-help/#findComment-3163002
I get 50fps and 120-1fps with CF. My CPU is 100% load. And when I oc I get less frame drops, no oc is 60-70fps 4.6ghz oc is 120-40fps. Both have CPU usage at 100% and no oc has GPUs at 60 oc has GPUs at 85-90... How can I fix this? I have latest drivers.
https://linustechtips.com/topic/231300-i5-4690k-help/#findComment-3163013
what resolution you run at?
im not sure how to fix your issue.  Overclocking my cpu did not give me any performance gains in bf4 unless i was playing single player.
i had issues with 7950's cfx. driver issues and poor results in bf4. I went back to Nvidia and haven't incurred any problems thus far.
https://linustechtips.com/topic/231300-i5-4690k-help/#findComment-3163041
1080p. Thanks in advance.
https://linustechtips.com/topic/231300-i5-4690k-help/#findComment-3163046
hitting 100% CPU load to play 1 game seems rather odd, and its the latest i5 too, not some cpu from 5 years ago. what are your cpu temps when you overclock? sounds like thermal throttling or an unstable OC.
https://linustechtips.com/topic/231300-i5-4690k-help/#findComment-3165991
https://linustechtips.com/topic/231300-i5-4690k-help/#findComment-3178093
