Drive bracket adapter thingies
Go to solution Solved by Clyne,
You two have any 5.25 to 2.5 ones in mind? Amazon loaded after damn near 3 minutes.
This one says in the Title "5.25 to 2.5 or 3.5"
http://www.amazon.com/gp/product/B005OJFASY/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=1944687462&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0094D8UGU&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=05KXPV1F9XJJDKQNQ3C5
I'm kinda in need of some 5 1/4 inch to 3.5/2.5 inch drive bracket converter thingies. It will be used in my grandma's HP, so it CAN NOT have a front panel, it just needs to be a bracket. And I only have one spot open, so it can't be double height. I would look myself, but LTT is the only thing my grandma's internet seems to be able to handle ATM.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/231293-drive-bracket-adapter-thingies/
I know of a 2.5" to 3.5" Silverstone has on Amazon and Newegg, but not a 5.25" to 3.5/2.5... Hopefully others can link you to some. I am quite busy right now as my computer will be torn down again a little later.
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
It doesn't have to be both, silly. 5.25 to 2.5 and 5.25 to 3.5 are both fine.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Main rig on profile
VAULT - File Server
OptiPlex 7040M
