Replacement Cable for AKG Q701s
KoolBeans
Hey guys i need a replacement cable for my AKG Q701s. I have been looking online and all i could find is the standard 1.5 meter one(s) that i already have, however i am looking for a shorter one because i am currently not using most of the length on the cable. Thanks in advance
-KoolBeans
I'm a undercover agent posing as CoolBeans. Also I am a massive scrub
Going DIY is a plus. Just search for the plug name/type, and order from ebay. Only need a basic soldering skill, and the satisfaction of using something you build yourself is the plus bit :)
