Im thinking about buying a 128GB Samsung 850 Pro for my OS and Programs and a 500GB Samsung 840 Evo or 850 Evo and use a 1TB HDD for Documents, Downloads and Media. I would like to know if i should do anything differnet?
i7 4790k | ASUS Z97 Gryphon | 8GB Corsair XMS3 1333Mhz | Asus Direct CUII GTX 770 1267/3829 | Stock Cooler | Antec Neo Eco 520W | WD Green 1TB
Silverstone TJ08-e | Klipsch Promedia 2.1 | Razer Tiamat 2.2 | LG 24EN43VS | Razer Naga (2010) | Razer Lycosa (2010)
Planned PC Upgrades: https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=325661&action=wish_lists
https://linustechtips.com/topic/230870-ssd-help/
get one 500GB or 1TB 850 pro for OS, programs, games, and files
Then a 2 or 3TB HDD for large files
https://linustechtips.com/topic/230870-ssd-help/#findComment-3158685
Would putting two 256GB 850 Pro's in RAID 0 be a good idea instead of one big 500GB SSD
https://linustechtips.com/topic/230870-ssd-help/#findComment-3158906
No. There can be issues with raid 0, and some times you will have to reinstall everything to fix it.
So personally I would avoid raid 0 and would rather have more reliable and larger storage. The speed boost is not as significant as it is between a HDD and SSD.
If you need more speed I recommend you wait until SATA express.
https://linustechtips.com/topic/230870-ssd-help/#findComment-3159005
Actually, I found an article from some time ago about 2 ssd in raid 0 vs 1 larger ssd.
http://www.tomshardware.com/reviews/ssd-raid-benchmark,3485.html
If you're planning an upgrade and want to know whether to buy a couple of 128 GB drives and put them in RAID 0 or just grab a single 256 GB SSD, for example, the answer still seems clear enough to us: just grab the large drive and use one.
There are of course exceptions. SATA 6Gb/s currently limits us to 500+ MB/s reads and sub-500 MB/s writes. Sometimes, that's just not enough. Just take those raw AVI captures mentioned earlier as an example. We use four Crucial m4s in RAID 0 to make sure we aren't dropping any frames. In a case like that, RAID 0 is a must-have, and the fact that only captured video resides on the array means that a failure would be a fairly superficial loss (except the cost of the drive). If you have an application like that, well, then you already know what you need, and you know that a large, single drive isn't going to get the job done.
Sound: Custom one pros, Audioengine A5+ with S8 sub.
K70 RGB
https://linustechtips.com/topic/230870-ssd-help/#findComment-3159046
The speed boost in a RAID 0 is very significant. I run a RAID 0 with two 120GB SSD's and I have two 1TB drives in another RAID 0. I have an external 500GB drive to backup data and I use flash drives to backup even more data. I would suggest an SSD RAID 0 using 120GB or 240GB drives. A standard magnetic Hard drive of 2TB or more or a RAID 0 with 2-4TB for large files. RAID 1's are for building NAS type stuff or for server type systems where they need redundancy.
https://linustechtips.com/topic/230870-ssd-help/#findComment-3159632
