Five questions. Ok this might be easy.
1. p(bx + a) = q(x - c)
How can I solve x?------------------------------
2. Four cubes has the combined volume of 13 dm^3. The cubes' sides relates to each other as 2 : 3 : 4 : 5.
What is the length of the smallest cube's side?---------------------------
3. Person A paints a wall in 4 hours. For person B it takes 6 hours to paint the same wall. How long would it take them to paint the wall if they do it together?-------------------------------
4.(x + 2)^2 = 16. How am I supposed to calculate this? I got to x^2 + 4x = 12, then what?-----------------------
5. A balloon rises with a constant velocity h meters in t hours. How high does it rise in n hours?----------------
Ok so that's it
https://linustechtips.com/topic/230063-help-with-math-done/
To solve it you need to find out what the volume is of the smallest cube which is 2/(2+3+4+5). Then you have the volume of the smallest cube. Then just (I don't know what to call it) take the cube root (Not square root, so the cube root of 8 is 2 because 2^3 = 8) and you have the smallest side.
3.
Person A does 25% per hour or 0.25X
Person B does 16.67% per hour or 0.1667X
Total is 0.25X + 0.1667X = 1 for the entire wall
5.
The balloon rises h metres in t hours so it rizes h / t metres per hour (so if it rises 50 meters in 0.5 hours then it will rize 50/0.5 = 100 meters per hour). So in n hours it rizes (h / t) * n
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148602
To solve it you need to find out what the volume is of the smallest cube which is 2/(2+3+4+5). Then you have the volume of the smallest cube. The just (I don't know what to call it) take the cube root (Not square root, so the cube root of 8 is 2 because 2^3 = 8) and you have the smallest side.
3.
5.
The balloon rises h metres in t hours so it rizes h / t metres per hour. So in n hours it rizes (h / t) * n
Doe jij VWO ofso? (dutch)
CPU: Intel I7 4790K 4.8 Ghz || Mobo: ASUS ROG Maximus Hero 6 Z87 || Ram: Corsair Vengeance 16 GB 1600 Mhz || GPU: ASUS GTX 980 Ti STRIX || Storage: 2 x SSD Samsung 840 EVO 250 GB RAID 0 HDD Western Digital 1 TB Black || PSU: Corsair AX 860 watt || Cooling: 2 x AF 140mm (front), 2 AF120 Blue LED (bottom and back), 2 SP120 (top on radiator) ||  CPU cooler: Corsair H100i GTX || Case: Corsair obsidian 750D <3 <3 <3
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148611
I'm doing university right now, I have done VWO yes :P. Besides none of these are very difficult aside from the first one, that one is a bit tricky
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148614
That is why your are so smart! :P
I do MBO lvl 4, one lvl lower than HBO!
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148619
Question 4 is a quadratic equation and you can find x with this:
x^2 + 4x = 12
x^2 + 4x -12 = 0
x^2 =a
4x=b
12=x
lol that's crazy, I have no idea how they thought you could calculate that. Thanks anyways
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148621
Done the first one too now. Give me a moment
1.
p(bx+a) = q(x-c)
pbx + pa = qx - qc
pbx = qx - qc - pa
pbx - qx = -qc - pa
x(pb - q) = -qc - pa
x = (-qc - pa)/(pb - q)
Call me out on a mistake I may have made, be it calculation or typing errors
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148625
3.
5.
very nice, thank you
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148626
1.
p(bx+a) = q(x-c)
pbx + pa = qx - qc
pbx = qx -qc - pa
pbx - qx = -qc - pa
It says in the book:
x = (ap + cq)/(q - bp).
The original thing was (bx + a)/q + (x - c)/p
So I multiplied both numerators with qp, was left with p(bx+a) = q(x-c) . Should I have done that?
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148651
You made a mistake there. The original is (bx+a)/q + (x-c)/p. That means if you bring the (x-c)/p to the right of the equals sign it becomes MINUS (x-c)/p. Not plus
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148703
1.
p(bx+a) = q(x-c)
pbx + pa = qx - qc
pbx = qx - qc - pa
pbx - qx = -qc - pa
@Archangel1994 has the same answer as the book just expressed slighty differently
ap = pa
cq = qc
bp = pb
so:
(-qc-pa)/(pb-q) = (-cq-ap)/(bp-q) = [-(ap+cq)]/[-(q-bp)] = (ap+cq)/(q-bp) {negatives cancel in this last step}
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148711
And I think all the questions have been solved but tag me if you need alternative solutions or explanations because I'll be able to help :)
I knew I forgot something. Thanks for the negative cancellation
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148725
omg sorry. The original thing was (bx + a)/q = (x - c)/p
So to get rid of /q and /p you must multiply both sides with qp right
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148728
ap = pa
cq = qc
bp = pb
so:
yes ofc
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148734
Aaaaah do it right immediately :P. I got all confused about my calculations now. Yes you need to multiply both sides by pq.
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148737
I'll make the math equation equation easier for you
1. x= (-ap-qc)/(pb-q)
4. (x+2)^2=16 => x+2=4 OR x+2=-4
Scarlet KnightIntel Core i3 6100 || Antec A40 Pro CPU Cooler || MSI Z170A Gaming M5 || Kingston HyperX 16GB DDR4-2133MHz || Samsung 850 Evo 120GB || Seagate Barracuda 1TB || Gigabyte G1 Gaming R9 390X 8GB || Seasonic M12II 620W || In Win 503 || Corsair Strafe || Steelseries Kinzu V3 MSI Edition || Dell UltraSharp U2414H || Xiaomi Alumunium Mouse Pad (S)
#Gadget:
Phone: BlackBerry Classic Q20, Samsung Galaxy Note 4 S-LTE SM-N916S
Console: PlayStation 4 500GB CUH-1206A
Tablet: iPad Air 2 16GB Wi-fi Only
Laptop: MSI GE62 (i7 4720HQ || 8GB DDR3 || NVIDIA GTX960M || Samsung 650 EVO 120GB + 1TB HDD)
In-ear Monitor: Xiaomi Piston 3.0
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148748
What you can also do is because both the left and right term are fractions  0a68e73c11ad2348d7f564e980ecdbab.png like this you can also do something else.
Say you have 2 fractions  0a68e73c11ad2348d7f564e980ecdbab.png and  0a68e73c11ad2348d7f564e980ecdbab.png. You can do cross multiplication with this. Take the top of the left fraction and multiply it with the bottom of the right fraction and vice versa. This will give you 3*4 = 3*4 in this example.
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148749
How can (1/5)^-2 be 25?
2 / (1/5) = 2 * (5/1) = 10/1 ???
(1/5)-2 = 52 = 25
a-n = (1/a)n
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148759
(1/5)^-2 means (1/1/5)^2 or 5^2 = 25
#Gadget:
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148761
1/5 = 0.2
0.2 ^-2 = 25
Remember that is exponent, not just multiplication
https://linustechtips.com/topic/230063-help-with-math-done/#findComment-3148764
