Ok so i have really heavily modded skyrim and i have a few issues maybe you could help with. I will just list problems and maybe you could list maybe what mods are cousing it/ possible solustions
1. cant load a game into whitrun
2. random dwarven machine things outside of whitrun and bleak falls
3. just random crashes in general not to desktop just a freeze
Thanks for any help :D
https://linustechtips.com/topic/229844-modded-skyrim-problems/
Likely a mod conflict. Did you read through the mods that you installed to be sure they didn't conflict with another mod? I know it's a chore to do, but it'll eliminate these issues from happening.
ye i chose carefully
https://linustechtips.com/topic/229844-modded-skyrim-problems/#findComment-3145481
I would just get a new game folder and then remod it more carefully. Back up your saves to
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/229844-modded-skyrim-problems/#findComment-3145492
How do you expect anyone to help you when you haven't even listed any of said mods? The information you provided is as vague as it gets, all I can say is that usually in cases like this it's just a mod conflict. How many are we talking about here? Under or over 100 mods?
3x Dell U2414H Triple Monitor Surround @ 5760x1080 / Corsair Obsidian 900D / ASUS ROG Z97 Maximus VII Hero / i7-4790K @ 4.4GHz / 2x EVGA SC GTX 780Ti SLI @ 1150MHz / 16GB GeiL DDR3 RAM @ 2133MHz / 120GB Samsung 840 EVO / Corsair AX1200W PSU
Gallery: [1] [2] [3] - Fire Strike Score - Steam Profile
https://linustechtips.com/topic/229844-modded-skyrim-problems/#findComment-3149017
Have you tried getting horse mods c:
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/229844-modded-skyrim-problems/#findComment-3149062
If you can't load into whiterun you could have a corrupt save or its just a mod conlfict. Heavily modded skyrim can result in frequent crashing  and CTD's due to memory limits and mod conflicts, the latest version of SKSE includes a patch that helps the way the game allocates the memory helping stability. Also have you tried cleaning the master files & mods with TES5Edit and sorting your load order with LOOT?
https://linustechtips.com/topic/229844-modded-skyrim-problems/#findComment-3152161
