Some of you may be fimiar with my dual ITX system "Twofold" for those of you who aren't the TLDR version is that it's an ancient Aopen ATX case that I modified to fit two ITX motherboards in. Among the hodgepodge of system components were a pair of PNY GTS 250 1GB XLR8 GPU's one that I bought from @ONOTech here on the forum and another that I bought shortly after from ebay. Currently Twofold is out of action and one of the two GTS 250's is in a PC that I put together for my brother, the other one basically ended up sitting on me desk being unused. Last night (actually very early this morning) I was speaking to a friend on teamspeak and we were speaking about hardware and basically I ended up thinking about how I wanted backplates for the 760's in my main rig and then I thought "how hard could it be to make them?" well after a bit of thinking I decided that the next day I would give it a spin and use my GTS 250 as a test bed for my work.
After searching my parts cache for a suitable piece of metal to make the back plate out of and finding nothing I started to think about using other materials, idea's for wood, plastic, and even cardboard back plates came and went and I settled on plastic as it isn't cardboard and I surely had something around the house that I could sacrifice to the project. After searching and searching I found nothing suitable until I hit the kitchen for a drink, while getting a cup I saw one of the many Tupperware containers and that's when it hit me that it would be perfect. I chose the largest one and after measuring to ensure that it was large enough(it was just big enough) I set to work making a template and cutting the lid. After cutting it and then a bit of trimming to shore up the uneven cuts I painted it and used some leftover hardware from building Twofold to attach the back plate to the card. I thought it looked pretty good but I thought it would look even better if I removed the stickers from the metal shroud so I did that as well.
Here's what I did
What the card looked like before modification
Source material
Traced template
Tool I decided to use to remove the rim of the lid
I really love this exacto set, best $20 tool set I've bought
Rim removed and template traced onto the lid
Backplate cut out
SLI finger cut out
Test fit (more trimming required after fit)
Paint I decided to use, well I say decided but it was this or either an emerald jewel green or a metallic royal purple so....not really much choice there.
Before paint
After a few coats
A few more coats
Finished, I thought it turned out really good.
Removed the stickers from the GPU shroud
"Glamor" shot <lel
The back
That's nearly it, before any of you mention it I know there's a big old belly button in the center of the back plate and I'm going to try to get a sticker made to cover it. Aside from that it's done and I really like how it turned out. It could be a bit better but considering that the whole thing took about 20 minutes to do not counting the paint drying I thought it was good. That's it and thanks for reading.
Sincerely,
Lord Pantaloons
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/229624-project-cheapskate-backplate/
That's the sexiest backplate I have ever seen.
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
Wow I really wasn't expecting such a positive reaction, I was really expecting to see quite a few people take the piss out of me for using a tupperware lid to make a back plate. I got my mom to print out some stickers but the size I told her to use was too small so she will reprint them tomorrow in a larger size. I will update the thread if the larger stickers work out.
That fucking SLS mousepad. Goddamnit Pants hahahaha.
But seriously, that backplate looks sweet!
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
Alright, unfortunately the whole sticker idea fell through. I got ones that were the right size but the still required a bit of trimming and doing that left white edges that were VERY visible when they were stuck to the back plate and I didn't like how it looked. So as it stands now the bellybutton is here to stay until I find another way to cover it, I thought about using one of the EVGA case badges that came with my GPU's but I can't find them. Anyways thanks the positive comments and I hope some of you give this a try too. I would like to see what idea's you all come up with and what interesting materials you might use.
  • 1 month later...
That turned out better than I expected. Looks great. :D
What's the purpose of a plastic backplate? Arguably the metal ones dissipate heat, but I don't see the purpose to the plastic one. Looks?
Good job although I thought the transparent blue was sexy.
Play the greatest game ever. TF2. http://www.teamfortress.com/
Metal ones don't actually help much with dissipating heat. A backplate is more for protection, rigidity, and looks.
Thanks though go figure I did all that work and now the GPU is dying so....fml
It's for looks, it's floppy and provides no support whatsoever and it obviously can't dissipate any heat in fact it might trap some lol. What Woodenmarker said was spot on though.
Hey if your looking to get a sticker to cover it i was looking at moddiy.com and noticed they have a sister site called modsticker.com, you could try THIS STICKER  Which is a metal sticker that says NVIDA with the logo on it for $1.99 USD. Might just cover that ugly spot, and since its a metal badge it will stand out very nicely against the paint job and look more like it was meant to be there.
Looks nice, I'll keep that in mind the next time I do this. The 250 is dying so I'm not going to mess with it anymore.
  • 1 year later...
On 10/8/2014 at 9:26 AM, Pugs501 said:
What the
Post from 2014
Video from 2016.
No edit.
Wat.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
