building my first system
Go to solution Solved by ImBleu,
Always. Use. PCPartpicker. Please.
As for your choices I agree with the 550D and 970, the Ax860i is a bit much and a 760i would've sufficed for quite a bit cheaper. I'd go for the 4690k as an easy overclock translates to more performance. 8GB is enough for a gaming rig, in my opinion but 16GB would do better. And I swear by Corsair SSDs, Intel would be the second best to me.
Motherboards is a different story. I've used MSI motherboards in Z87 but for my z97 upgrade I'm going for the Hero or Ranger, depending on what I can get my hands on at the time :)
EDIT: And welcome to the LTT forums @Nepheliod :)
I'd also like to add that incase you are interested; this is my build plan so far:
NZXT H440
Intel i5-4690k
Asus Strix 970
Asus Maximus Hero
Corsair AX760
Corsair H105
Corsair Vengeance Pro 2133Mhz 8GB
Corsair Force LS 128GB (x2)
WD 1TB HDD (x2)
While it isn't your build it is quite similar. So that could give you an idea of what I believe is a strong build for the price point.
If anyone see this would you all mind helping me to pick some of my build part
What i have bought is
Casing-Corsair 550D
PSU-Corsair AX860i
GPU-Asus Strix Geforce GTX970
And these i can't make decision of which to take
CPU-Intel Core i5 4690 or 4690k
RAM-Kingston Hyper X Fury PC 1866 DDR3 8GB or 16GB
SSD-Intel 530 series 180GB or Kingston Hyper X 3K 120GB
Lastly motherboards is the hardest decision for me due to there is so many type of board out there and i don't know which is good
there is a few i choose ~Asus Maximus VII Ranger
                                    ~Asus Maximus VII Hero
                                    ~MSI Z97 Gaming 5 or 7
                                    ~MSI Z97 MPOWER
Please and thank you first for your opinion
https://linustechtips.com/topic/229069-building-my-first-system/
i5 4690K and MSI Gaming 7 ( I have that processor and 9 AC) also Crucial and Samsung make good SSDs MX100 and 840 Evo, what about CPU cooling?
Intel Core i5 4690K @ 4.2Ghz | Evga GTX 780 Ti SC ACX with backplate | MSI Gaming 9 AC | 8GB (2x4) Corsair Vengeance Pro Silver 2400 MHz | Corsair H105 128GB Crucial MX100 | Toshiba 2TB | Evga 750G2 | Corsair Obsidian 750d | Be Quiet Silent Wings 2 PWM (3x140mm & 3x120mm)
https://linustechtips.com/topic/229069-building-my-first-system/#findComment-3135229
NZXT H440
Intel i5-4690k
Asus Strix 970
Asus Maximus Hero
Corsair AX760
Corsair H105
WD 1TB HDD (x2)
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/229069-building-my-first-system/#findComment-3135234
what about an asus z97 a/ar or gigabyte gaming 3/5/7
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
https://linustechtips.com/topic/229069-building-my-first-system/#findComment-3135245
Casing-Corsair 550D
PSU-Corsair AX860i
                                    ~MSI Z97 MPOWER
CPU: If you dont wanna overclock get the 4690 if you do then get the K-version
RAM: 8GB is sufficient for gmaing
MOBO: If you dont get the K-version CPU then you can buy a cheap H97 chipset Mobo otherwise my suggestion would be the MSI Z97 Gaming 5.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
https://linustechtips.com/topic/229069-building-my-first-system/#findComment-3135270
budget is kinda had to give you due too i'm from malaysia so everything here have different price range from your country and over here doesn't have many type of board too
and i use this to jugde my price
http://www.hardwarezone.com.my/priceLists/preview/476192#.VDQC2vnogSQ
if you follow this my budget is around RM5.5k to RM6k
https://linustechtips.com/topic/229069-building-my-first-system/#findComment-3135271
Definitely the 860i is overkill, you're probably not even going to need 750 but it's better to have a little extra anyways, 860 would just be a waste of money really. Depending on your budget, I'd either suggest a Cooler Master air cooling option ~$40 or an AIO watercooling option from either Corsair, NZXT, or Cooler Master (depending on budget and rad size you can fit). I like the 550D, but I'm not sure it beats out cheaper silence optimized cases like the Fractal Define R4 or NZXT H440, both of which come in at a lower price and the H440 has that sleek looking PSU cover. Samsung, Crucial, Corsair, Intel, Kingston--they all make very good SSDs, so that part will be up to you; the two you've listed are excellent value per dollar performers.
Fractal Design Arc Midi R2 | ASUS Z97-A | Intel Core i5 4690K | G.Skill Ripjaw 4 GB (desperately needs upgrade) | MSI Radeon R9 290 | EVGA SuperNOVA 750 G2 | Samsung 840 EVO 250 GB SSD | Seagate Constellation 1 TB HDD (also needs upgrade) | NZXT Kraken X61 for CPU | NZXT Kraken X61 + G10 for GPU | Corsair M45 | CM Storm Quickfire TK | ASUS Xonar DSX | Denon AD-H2000
https://linustechtips.com/topic/229069-building-my-first-system/#findComment-3135308
NZXT H440
Intel i5-4690k
Asus Strix 970
Asus Maximus Hero
Corsair AX760
Corsair H105
WD 1TB HDD (x2)
I agree with the power supply option too but i'm planning for future expansion usage just in case
https://linustechtips.com/topic/229069-building-my-first-system/#findComment-3135330
totally agree with you but i can't get all this stuff with this price point due to i'm from Malaysia so everything here is a lot more expensive and i didn't see fractal design case near my area
and i'm going with water cooling cpu
psu is for future expansion use plus around here i just add a few buck to it i can get bigger psu
https://linustechtips.com/topic/229069-building-my-first-system/#findComment-3135355
 how about if i go with colour scheme which of my choice would look nice with my GTX970 n perform well
https://linustechtips.com/topic/229069-building-my-first-system/#findComment-3135367
i'd recommend a gigabyte gaming 5 to match the 970 you chose
https://linustechtips.com/topic/229069-building-my-first-system/#findComment-3135384
The 970 strix is mostly black. The MSI board is mostly black aswell with some red accents - id say it would fit best. Asus boards have too much red imo
https://linustechtips.com/topic/229069-building-my-first-system/#findComment-3135401
I see. I'm still not sure if you would need the 860 though, especially since having a significantly overpowered PSU can mean less efficiency. What kind of expansion are you planning? You should check around the forum about the H100i, as I've noticed a number of threads about problems people have had with it.
https://linustechtips.com/topic/229069-building-my-first-system/#findComment-3135404
totally agree with you but i can't get all this stuff with this price point due to i'm from Malaysia so everything here is a lot more expensive and i didn't see fractal design case near my areai
From Linus's latest videos, 16GB DDR4 + i7-5930k Overclocked + 4x GTX980 came up to about 820watts. I don't really think you need the 860 in my opinion :)
https://linustechtips.com/topic/229069-building-my-first-system/#findComment-3135484
Thank for all of your opinion i will take it into my consideration
Really thank a lot
https://linustechtips.com/topic/229069-building-my-first-system/#findComment-3141437
