Overkill *Red&Black* 350D Build (WIP)
monjanger
Build
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($336.99 @ Amazon)  :D Purchased :D
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($97.16 @ Amazon)
Motherboard: Asus MAXIMUS VII GENE Micro ATX LGA1150 Motherboard  ($207.98 @ SuperBiiz)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-2400 Memory  ($182.99 @ Amazon)
Storage: Samsung 840 EVO 1TB 2.5" Solid State Drive  ($439.80 @ Amazon)
Video Card: Gigabyte GeForce GTX 980 4GB Video Card (2-Way SLI)  ($555.91 @ Newegg)
Case: Corsair 350D Window MicroATX Mid Tower Case  ($109.99 @ NCIX US)
Power Supply: Corsair 760W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($184.99 @ Amazon)
Optical Drive: Asus DRW-24F1ST DVD/CD Writer  ($14.99 @ Amazon)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($90.26 @ OutletPC)
Case Fan: Corsair Air Series SP120 Quiet Edition (2-Pack) 37.9 CFM 120mm  Fans  ($25.47 @ Amazon)
Case Fan: Corsair Air Series AF140 Quiet Edition 67.8 CFM 140mm  Fan  ($17.81 @ OutletPC)
Total: $2855.87
Watercooling Custom Loop
EK CPU Block: EK Supermacy Elite ($127 @ FrozeCPU)
EKA VGA Block: 2x EK FC980 ($230 @ FrozenCPU)
Pump and Reservoir: EK D5 X-Top Pump Top w/ D5 Vario Pump ($170 @ FrozenCPU)
Radiator: x2 EK Cool Stream 240 Rad ($120 @ FrozenCPU)
Tubing: Primochill LRT Tubing 3/8 ID 10 Feet Red ($25 @ FrozenCPU)
Total: $775
Note: Build will change if I decide to do custom loop water-cooling! Only fans though.
If you do a custom loop and use the 350D I would strongly recommend cutting out the drive bays. With this you can have a 360 and a 240 rad, which would be more ideal for 2 GPUS and a CPU in one loop. Good luck with the build!
i7 4770k  ¬ MSI Z87-M Gaming ¬ Corsair Vengeance 8GB 1866Mhz ¬ R9 290x Crossfire ¬ Corsair 350D ¬ Corsair RM 1000
Good idea, I am not to much into case modding but I might go to NCIX for them to help me with the build, or a geeksquad place.
Don't even bother, learning how to build a pc/mod cases is pretty easy. Worst case you make a mistake, those do happen sometimes, and you can just try again.
Just don't lick your 4790k or something :P
Edit: Feel free to lick your heatsink, it'll taste funny but it won't hurt nothing
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
But I want to lick it... *creepy face*
Well...As long as it's your 300 plus dollars, do as you wish :P
We need to set up a support group for you and snickerz
Built in this case 3 times now its very roomy.  Let us know how the custom loop goes. Followed BTW. :)
