Hi! so ive got a big question, So ive had my computer for about 8-9 months now and its been really weird lately it keeps crashing the whole time and it freezes the whole computer like for about 1-2 min like i cant even touch anything neither can i thought or do anything for 1-2 and it happends like 2-3 times a day, and ive gotten fps drops time to time in games like League of legends, counter strike global offensive. Specs
Model AMD Radeon R9 280X
Memory 3072 MB, GDDR5
Connections HDMI, DVI
processor
Model AMD FX-8350
Speed 4.2GHz - Max Turbo
Number of Cores 8 pcs - Octa Core
RAM
Model Corsair Vengeance 8192MB (8GB)
Memory type DDR3 1600MHz
Hard Drive
Size 1000 GB
Connection 7200RPM - 6Gb / s - SATA
Motherboard
Gigabyte Model 970A-DS3P
Sound Card 8-Channel High Definition Audio
Internet 10/100/1000/Mbit Gigabit LAN
USB 2.0 / USB 3.0 6 & 2
Other
Chassis Cooler Master HAF912 - Infinity Edition
Power Supply XFX Core Edition 550W - 85% efficiency - 80PLUS
DVD Burner DVD ± RW Dual-Layer
SSD: 180gb samsung
Cpu cooler: H60 corsair
http://gyazo.com/1e8a09bb34b68480d7cc6d2fe0085116
Heres a pic on when the freezing happends, it freezes every program possible. i can move mouse etc but doesnt let me use any program, And i had no idea where to post this so sorry if its wrong place.
https://linustechtips.com/topic/228160-fps-drops-and-pc-freezing/
Update cats out of every single hardware
Edit keep the cats just update them  :)
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
Might wanna move this to troubleshooting
Eric S. Raymond used an E6600 from 2005 until 12/30/14 or open source software creation. Raw data computations in excess of 18GB each. Core 2 Duos still have tons of life left, my friend.
Update drivers?
Try ccleaner?
Look at task manager to see what process causes the CPU spike.
Other than that you will need to reinstall windows.
maybe there's dust or something that could be overheating PC? other than that I'd run an anti-virus program to make sure there's nothing bad going on in your PC
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
