HD 558 vs AKG612 Pro
SpaceSquid
So I am buying new headphones cause my G430 is gonna crap out soon. I listen to music, play games and watch movies. I know the ATH M50s are good but bad for gaming so I am deciding with these two. The HD558s are 50 dollars cheaper but they are pretty old and the AKG612 seem more comfortable. They are gonna be powered by Fiio E10K
Muh rig: i7 4770k, Cooler Master Hyper 212 Evo, MSI Z87 G45, Kingston Hyper X Blu 8GB, Samsung 840 EVO 120 + WD Blue 1 TB, Asus GTX 770 2GB, Corsair 200r + 2x Corsair AF 120 Blue + 1x Stock corsair fan, Corsair TX650, LG 27EA33V IPS, Steelseries Sensei Raw + QCK mini, CM Quickfire Ultimate Blue.
Just saying that the M50's don't suck at gaming but for $300 (Price I found for AKG612's) I would get the ATH-AG's
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
I cant comment on the AKG612 but I have owned a pair of HD558's for over 2 years now.  They are absolutely fantastic headphones.
You can get lost in the music.  Watch out though they have a lot of "sound leak".  Its how open headphones are supposed to be but still something to consider.
01010010 01101111 01100010  01001101 01100001 01100011 01010010 01100001 01100101
If you're interested in the 558 because it is cheaper, then go with a 518 as it is MUCH cheaper while still sounding similar to the 558/598. The K612 is only more comfy if you have a larger than average head or ears.
That's nahhhhht what they cost.
Oops those are the 712's. My bad.
So I should just go with the 558s?
AKG K612's are better but need some kind of amping.
Is the Fiio e10k enough to power them?
