So here goes:
Intel i7 4790k
Corsair H90, with a Noctua Nf-A14
Fractal Desgin Define R4
ASUS Z97 A ATX
16gb Hyper-X Fury
Corsair RM 850watt psu
2x GTX 980 SLI
3tb Western Digital Black
240gb Crucial M500 SSD
2x be quiet Silent Wings 2 PWM Case Fans
ASUS PB278Q
switch that cooler out for a h105
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
Overkill GPU. 2x GTX 970 is much cheaper and nearly as good, and heck, a single 970 doesn't do too bad at 1440p.
Also, there is no color coordination in your build.
WD Black is overrated and not that much faster.
Corsair RM Series PSUs are ehh...
There are better Corsair units and other units from other brands.
You can't fit an H105 in a define r4, only an H100/H100i. The h105's radiator is too thick.
Aesthetics of rigs matter
42
If you're interested, participate in LTT Build Offs
